Overview
Enhancement to existing script ID 709. Utility to create MPCs for modelling cyclic symmetry on a solid mesh wedge model.
1. Create faces on the solid elements and a cylindrical coordinate system at the centre with the z axis in the models axial direction
2. Run the utility (file-run-tcl/tk script) (both script files must be in same directory
3. Select the faces on one side, then select the faces on the other side to connect together
Limitation
The faces used must have a matching mesh pattern.
Functionality
Model/Analysis
Subfunctionality
Model Setup
Interface
OptiStruct
