Defining Geometry Motion from a Text File
User: "Come_Duret"
Updated by Come_Duret
Overview
This model is an EDEM coupling interface application that allows you to define the movement of a geometry based on a text file. In the attached "motion_text.zip" you will find the following:
  • motion_text.cpp : The source code
  • motion_text.exe : The .exe of the compiled application
  • motion_text.txt: The preference file associated to the application. In this preference file:
    • Line 1 : Name of the geometry that will be moved
    • Line 2 : timestep, number of data points, simulation end time
    • Line 3 and after : Time Vx Vy Vz ωx ωy ωz, where V is the velocity and ω is the angular velocity
  • example folder : contains the example simulation deck
This can be useful when the geometry has a complex motion that would be difficult to define using only EDEM kinematics, and without having to couple EDEM with a MBD software. As an example, one can use the following workflow:
  • Calculate the motion of the geometry in an MBD software
  • Export the motion data (global axis, at the center of the geometry) as a text file and enter the necessary information in "motion_text.txt" as described above
  • Set up your EDEM deck, start the coupling server and run the .exe application
  1. Set motion_text.txt with the name of the geometry to be controlled in EDEM, and define its velocities and angular velocities.
        Place this file in the same folder as motion_text.exe.
  2. Launch the simulation deck, then activate the coupling interface from the Simulator.
  3. Run motion_text.exe. This should automatically start the simulation.
Comments
No comments on this post.
Share projects with the Community
Share your models, scripts, workspaces, and more with the Altair Community.
New Exchange Project
