Overview
Here you will find the UDL source code for an example of the Bonded Particle Contact Model built in to EDEM:
Pre-Requisite
For information about compiling EDEM API Models please see:
https://community.altair.com/csm?id=kb_article_view&sysparm_article=KB0037690
or the EDEM Help:
https://2022.help.altair.com/2022.2/EDEM/Programming_Guide.htm
More EDEM and EDEM API Tutorials can be found here:
https://community.altair.com/community?id=community_blog&sys_id=5e7dc459979de950e3b0361e6253afae
This simulation uses a bonding contact model to demonstrate particle bonding. A wedge cuts through a box of particles that are loosely bonded together.
The model is using the index method to modify a custom property. Using the index method provides performance improvement. The torque calculation for the rolling friction has also been updated to comply with the changes introduced in API version 2.4.
