Here you will find the UDL source code for an example of the cohesion contact model proposed by Johnson, Kendall and Roberts.
This model has been updated to API 3.9 (EDEM 2025) by @Renan
For information about compiling EDEM API Models please see:
https://community.altair.com/csm?id=kb_article_view&sysparm_article=KB0037690
or the EDEM Help:
https://help.altair.com/edem/topics/programming_guide/introducing_the_programming_guide_c.htm
More EDEM and EDEM API Tutorials can be found here:
https://community.altair.com/community?id=community_blog&sys_id=5e7dc459979de950e3b0361e6253afae
This JKR model DLL gives the same results as the EDEM built-in JKR model when run with CUDA, but the results are incorrect with the CPU solver. Could you please help modify the code to fix this issue?
Share your models, scripts, workspaces, and more with the Altair Community.
