Overview
This script will create a HyperView measure entity of Type Minimum Distance. It will use node-by-Comp method for both measure pairs used.
Pre-Requisite
Edit lines 9 / 12 with Component IDs used for the measure calculation (measure pairs).
 The method used will be node-by-Comp for both measure pairs.
 Pair 1 can contain 1 Component.
 Pair 2 can contain multiple Components.
Run script e.g. from DropDown  File > Load > Script
 Measure of Type Minimum Distance will be created.
