Support for Quasi Static analysis
I have performed Quasi static analysis in Radioss solver, but couldn't able to validate results with actual one. Since I am new to radioss i took reference of E book. I choose M36 Plast Tab mat card. My material is D513 Steel.
Request to guide reply.
I am applying CLOAD of 100000N on a plate through rigids, I have completed run successfully.
But i can see only 3000N of contact force had applied on bracket(PFA Grpah for ref.)
For contact between plate and bracket i have used Type7. I need to apply fully 100KN of force on bracket.
Request to guide on above query.
I would suggest you to check on the constraints if the forces match the imposed force.
Also the force in the rbody.
Regards
Hello sir,
Error- ELAPSED TIME= 3049.96 s REMAINING TIME= 5984.25 s
-- RUPTURE OF SHELL ELEMENT : 327334 AT TIME : 0.5066E-01
-- RUPTURE OF SHELL ELEMENT : 327335 AT TIME : 0.5066E-01
-- RUPTURE OF SHELL ELEMENT : 327336 AT TIME : 0.5066E-01
-- RUPTURE OF SHELL ELEMENT : 327337 AT TIME : 0.5066E-01
-- RUPTURE OF SHELL ELEMENT : 327338 AT TIME : 0.5066E-01
-- RUPTURE OF SHELL ELEMENT : 327340 AT TIME : 0.5066E-01
-- RUPTURE OF SHELL ELEMENT : 326948 AT TIME : 0.5066E-01
-- RUPTURE OF SHELL ELEMENT : 326952 AT TIME : 0.5066E-01
-- RUPTURE OF SHELL ELEMENT : 327293 AT TIME : 0.5066E-01
-- RUPTURE OF SHELL ELEMENT : 327296 AT TIME : 0.5066E-01
-- RUPTURE OF SHELL ELEMENT : 327297 AT TIME : 0.5066E-01
-- RUPTURE OF SHELL ELEMENT : 327300 AT TIME : 0.5066E-01
-- RUPTURE OF SHELL ELEMENT : 327301 AT TIME : 0.5066E-01
-- RUPTURE OF SHELL ELEMENT : 327302 AT TIME : 0.5066E-01
-- RUPTURE OF SHELL ELEMENT : 327305 AT TIME : 0.5066E-01
-- RUPTURE OF SHELL ELEMENT : 327306 AT TIME : 0.5066E-01
-- RUPTURE OF SHELL ELEMENT : 327309 AT TIME : 0.5066E-01
-- RUPTURE OF SHELL ELEMENT : 327310 AT TIME : 0.5066E-01
-- RUPTURE OF SHELL ELEMENT : 327314 AT TIME : 0.5066E-01
ANIMATION FILE: 3A012 WRITTEN
**ERROR : TIME STEP LESS OR EQUAL ZERO
Request to support for above.
Hello sir,
Run is completed successfuly but in hypergraph when i checked Rbody force it is only showing 2.25 tons, when i checked contact force it is showing 10 Tons. Please see graphs.
I have applied 10Ton(100Kn) of force but now i have confused what amount of force exactly applied on brackets
Request to reply.
Hi
I do not understand clearly you query.
you said you did quasi static analysis, So I believe you applied the loading during enough long time.
As a way to check the quasi static condition, you can compare the kinetic energy to the internal energy.
Quasi static would render small kinetic energy compared to the deformation/internal energy.
The selection of the material law would not effect the condition.
I hope this is helpful
Regards
