EDEM API: Particle Body Force – Handling strings with the GPU API
User: "jerrinjobs"
Updated by jerrinjobs
Overview
Attached you will find an example of how to handle strings when working with the GPU API. The short version is you handle everything that deals with strings on the CPU and use parameterData as a proxy when working with the GPU.
Pre-Requisite
The example deck was made from scratch using EDEM 2023.0, so those running that version or later should be able to open the deck.
The example considers two particles and applies a torque to one, based on the particle type. Although you only need externalForce() and getParticleParameterData() to make this work, I’ve added an intermediate function, isExampleParticle(), to highlight that both these functions need to work with the same string. This intermediate function is not necessary but hopefully reinforces the idea that the strings used in externalForce() and getParticleParameterData() should match.
Comments
1 - 1 of 11
    User: "QinHe_321"
    Altair Community Member
    any more detailed tutorial, I don't understand how cu file is generated. and there are also errors when I pack dll.
Share projects with the Community
Share your models, scripts, workspaces, and more with the Altair Community.
New Exchange Project
