Overview
A Reconnaissance Pod is a key system of an aircraft that provides stabilized and high-resolution images of a target during the flight.
 Download the Reconnaissance Pod .zip file to access the model and the analysis approach:
 - This model is a 2 DOF system made by different integrated subsystems such as: motors, controllers and multi-body system
- These systems must have a robust control in order to provide accurate images regardless of aircraft flight route deviation or maneuvers in high speeds
This example shows:
 - How to model a Reconnaissance Pod in MotionView
- Analyze the system in different fidelity levels
- Integrate the control system through the mechanical using a Closed Loop in Activate
- Run a co-simulation between MotionSolve and Activate
Follow steps given in the pptx
