Overview
Keep track of Flutter critical points more efficiently by parsing .out/.f06 files automatically to compare them with .op2 modal results. The benefit is to avoid manual work with a more appropriate environment for math operations.
Pre-Requisite
Flutter
Points
• Choose the directory where all f 06 and out files to be filtered are stored.
• Compose will automatically remove all spurious data to store only the blocks of interest
• The chosen directory will have now a pair of files log and png) for each filtered file containing the
• critical Flutter point
• Run the TCL script to plot the critical point along with the op 2 correspondent result in HyperView
