Product: SimLab
Product Version: SimLab 2020.1 or above
Auto Extrude
This tool is used for creating hex mesh for components, that are extruded in single direction or multiple direction. This tool is used to create Hex mesh automatically for PCB board with electronic chips and other components. It provides one click solution for components wherein the user has to select the bodies and specify the size for Hex meshing. This tool automatically helps to create a matching mesh between different bodies. So, no need to spend time for having imprint of CAD faces to attain matching mesh. "Allow quad mesh transition" option generates quad mesh with transition.
Mesh > Hex > Auto Extrude
Example: Single Extrude Direction
Example: Multiple Extrude Direction
