Study Management
- Use an Archive to share a study with someone or to move a study at a new location.
- Use Multi-Execution functionality to speed up the computation when it is possible.
- Use Inclusion Matrix functionality to leverage in existing data from other approaches.
- Run System Bounds Check (3 runs) rather than Nominal run (1 run) to check bounds consistency.
- Use Purge funtionality to minimize the size of your study directory by removing unnecessary run files.
Tip: Press F1 keyboard button from where you are in the tool to reach the Help related to the topic you are discovering.
HyperStudy Approaches - User Guide Map
Note: Please be aware that this map does not outline every HyperStudy use case.
Was this helpful? Let us know your thoughts!
