Hello Everyone,
Please find the below newly added features which will be available in the upcoming SimLab release (SimLab 2024.1).
Solution: Transient heat transfer
Solver: OptiStruct
- Radiation: Transient Heat Transfer Solution > Analysis > Loads and Constraints
- Support added to define radiation boundary conditions.
Solution: Linear Transient and Non-Linear Transient
Solver: OptiStruct
- Time-Dependent Tables: Linear Transient and Non-Linear Transient Solutions
- Added ‘Linear Smooth’ interpolation support for Time Dependent tables (TABLED1).
CAD Import
- Parasolid: File > Import > CAD
- A new environment variable is added “SL_INSTANCE_BODYNAME_IMPORT” to read the CAD instance name while importing the Parasolid model.
Tools
- Fill Holes: Geometry > Face > Fill
- Now, fill hole can be performed by selecting edge as input for Parasolid CAD bodies.
- Simplify Bodies: Geometry > Body > More tools
- Turning ON the “Don't post this message for this session” check box will not post the message next time while performing the operation. In SimLab 2024, this message will be posted everytime while using the “Simplify bodies identical to input bodies” option.
Mesh
- Tet Mesher: File > Preferences > Mesh > Volume
- Removed the “Use 2023 Tet mesher” option from the File > Preferences > Mesh > Volume.
Thanks & Regards,
Santhoshkumar
Sr. Manager, Quality Assurance
Altair | Nasdaq: ALTR
Connect with us: LinkedIn | Twitter | Facebook
#OnlyForward
SimLab learning center (SLC) | SimLab FAQ
