Hello Everyone,
Please find the below newly added features which will be available in the upcoming SimLab release (SimLab 2024.1).
Solution: Battery Thermo Electric
Solver: OptiStruct
- Battery Thermo Electric: Solutions > Applications > Battery
- OptiStruct battery thermal solution is supported.
- Thermal and electrical subcases are automatically coupled.
- Battery ECM parameters and initial conditions can be setup from analysis ribbon.
- Battery Model: Battery Thermo Electric Solution > Analysis > Battery
- Equivalent circuit model parameters can be defined from Battery Model.
- First and second order ECM circuits are supported.
- Parameters can be constant or bilinear tables.
Solution: Non-linear Transient Heat Transfer
Solver: OptiStruct
- Non-linear Transient Heat Transfer: Solutions > Physics > Thermal
- Non-linear transient heat transfer solution is supported.
- This is helpful for battery thermal management solutions.
Results
- Contour Results: Results
- RBODY results are supported for Radioss drop/impact analysis.
- An RBE body is created in assembly and RBODY results are mapped to it.
- Reaction forces and enforced displacements at rigid body reference nodes can be measured.
Tools
- Remove Details: Geometry > Body > Feature
- Remove details tool is extended to remove the details on the connected Parasolid bodies (General bodies).
- Create Bolt For Sheet Body: Advanced > Bolt Modeling > 1D Bolt
- New tool is added to establish the connections between sheet body bolt holes using RBE.
Thanks & Regards,
Santhoshkumar
Sr. Manager, Quality Assurance
Altair | Nasdaq: ALTR
Connect with us: LinkedIn | Twitter | Facebook
#OnlyForward
SimLab learning center (SLC) | SimLab FAQ
