Let’s have a look at the key features of Altair PollEx 2021.1!
Adding and modifying new license features
- New license feature code: PollExMFG is added for the PollEx manufacturing options which will draw the same 30 AUs.
- Changed license feature code: PollEx UPE application is available in PollExBasic feature which will draw 10 AUs from 30AUs.
Figure 1 – Altair Unit Chart for PollEx Products |
Adding "Altair License Utility"
- Now added in PollEx 2021.1 launcher.
Figure 2 – Altair License Utility in Altair PollEx 2021.1 Launcher |
Adding "Altair License Management System" setup panel
- The environment variable setting panel is added during install. This panel is only displayed if the environment variable has not been set.
Figure 3 – Altair License Management System in Altair PollEx 2021.1 Installer |
Adding design data saving option in PollEx PCB
- A new feature to save design data in a project directory with a compressed file (*.tgz) to share relevant data conveniently.
Figure 4 – PollEx PCB, Save Project Data into Compressed File (*.tgz) |
Added "SI Explorer"
- A feature to support pre-layout analysis "SI Explorer" menu to validate the design decisions throughout the design process, including the selection of parts, add materials, construct board layer stack-up and create the net topology.
Figure 5 – PollEx SI Explorer dialog |
- Upon executing PollEx SI Explorer, the SI Explorer dialog comes up. You can start pre-layout signal integrity analysis from the scratch.
- Create layer stackup
- Create VIA model
- Create Transmission Line Model
- Create Net topology (Single-ended, Differential, Multi-coupled)
Figure 6 – Built-in Topology Model Libraries |
- Perform Signal Integrity Analysis (Waveform, Eye-diagram, Network Parameter)
Figure 7 – Signal Integrity Analysis (Waveform) |
Adding a feature to display S/Y/Z parameters
- Adding a feature to display S / Y / Z parameter in Network Parameter viewer, PollEx SI. By using this function, it is possible to compare and measure by opening the S / Y / Z parameters extracted from various conditions.
Figure 8 – Network Parameter Viewer |
Adding an automation feature to support Multi-PCB structure
- Added a feature to generate system-level net topology automatically. By using this function, multi-level topology configuration and analysis between PCBs with different stackup is possible.
Note: In version V2021.1, only single net (Single-ended, Differential Pair) analysis is possible. The analyze function of multiple net topologies will be released in V2021.2 version.
Figure 9 – System Level Analysis Dialog |
Figure 10 – System Level Net Topology |
Adding a feature to support Rigid/Flexible PCB design
- System level signal integrity analysis is possible considering the multiple stackup structure designed as a Rigid/Flexible structure.
Figure 11 – How to Add Rigid/Flexible Stackup Structure |
Figure 12 –Analyze Rigid/Flexible Structure |
Adding a feature to extract SPICE Netlist
- Adding a feature to extract SPICE Netlist, you can select and determine the results of network parameter analysis. You can specify the output of the network analysis. (S/Y/Z Parameter, Spice Netlist, PSPICE Netlist)
- S/Y/Z Parameter: Network Analysis results are displayed as S/Y/Z parameters.
- Spice Netlist: Network Analysis results are saved in Berkeley Spice compatible format. (*.sp)
- PSPICE Netlist: Network Analysis results are saved in PSPICE compatible format. (*.lib)
Figure 13 – Selecting Network Parameter Analysis Result |
Adding a feature to assign analog input
- Added a function to apply analog waveforms such as a sine wave as an analysis stimulus during network analysis.
Figure 14 – Assigning a Sine Wave as a Stimulus for Network Analysis |
View the full Release Notes and download PollEx 2021.1 from Altair One.
