Panopticon 2020.1 is an important release of the platform and you should begin planning your upgrade now. With Panopticon 2020.1, we have provided new analytics tools, tweaked the UI to make the system easier to use, continued our development of cloud functionality, provided new native data connectors, and improved system performance.
Click here to read the release notes about this new version.
Click here to watch a short video walking you through the major changes in Panopticon 2020.1
Here's a high-level summary of the changes in Panopticon 2020.1:
Analytics: You can now make joins on multiple key columns of different data types and display a listing of current filters; both of these have been popular feature request over the past few years. We have also added new calculated column functions, a new time bucket type for monthly data, a new aggregation method, and new special filter parameters.
User Experience: We've made it easier to collaborate with your coworkers on dashboard designs, simplified theme and color palette editing functions, and provided simplified views of logged-in users and workbooks.
Server/Cloud Deployment: We now support automatic import of workbooks into the repository on server start-up, improved support for containerized and orchestrated environments (including Docker, Docker Swarm, and Kubernetes), integrated with OpenAM authentication, and made additional data source statistics available to server admins.
Connectivity: Panopticon now pools all Kx kdb+ connections automatically, allows easy authorization with Kerberized Kx kdb+ environments, and supports multi-record payloads in connections to real-time message queues.
Stream Processing: Clients utilizing Altair units pricing can now use the Streams processing engine at no additional cost, and the Streams Python transform now uses Apache Arrow with a 100X performance improvement compared to Panopticon 2020.0.
Download the Panopticon 2020.1 software and documentation using these links.
Visualization Server
Panopticon Visualization Server v2020.1.0 for Java WAR file
Streams
Panopticon Streams 2020.1.0 WAR file
Designer
Panopticon Designer v2020.1.0 (MSI & Setup) 64-Bit
Panopticon Designer v2020.1.0 64-Bit for "File Only" Deployments
Visualization SDK
Panopticon Visualization SDK v2020.1.0 64-Bit
Panopticon V2020.1 Release Notes
Panopticon V2020.1 Quick Start
Panopticon V2020.1 Web Authoring Quick Start Guide
Panopticon V2020.1 Web Authoring Guide
Panopticon V2020.1 Client User Guide
Panopticon V2020.1 Streams Guide
Panopticon V2020.1 Technical Fact Sheet
Panopticon V2020.1 Install Guide
Panopticon V2020.1 Server Install Troubleshooting Guide
Panopticon V2020.1 Reference Guide
Panopticon V2020.1 Embed Developer Guide
Panopticon V2020.1 Third-Party Guide
Panopticon V2020.1 Visualization Guide
Note: If you have problems with any of these links, please email panopticon@altair.com or file a support ticket to get help.
Click here to read the End of Life Statement for Altair Panopticon Java SDK, .NET SDK, and Designer for Windows Products.
Hugh Heinsohn
Solutions Marketing, Altair Data Analytics
