Hello, I am pleased to announce that PBS Professional version 2024.1.1 is now available for customer download on the PBS User Area, Altair Connect, and Altair One Marketplace.
PBS Pro 2024.1.1 is a bug fix release. The fixes include:
HPCPBS-30619 Cgroup hook crashes if ANY process on the system has more than two spaces in its name
HPCPBS-30539 resources used cput and mem not being accrued/reported on ubuntu platform
HPCPBS-30491 Windows mom is down after making windows-linux cluster
HPCPBS-30467 GQL queries/mutations bypass Access Control Lists (like acl users)
HPCPBS-30462 Sched Daemon Silently Crashes (aka cores)
HPCPBS-30411 bucket algorithm won't reuse a node between chunks with -lplace=free
HPCPBS-30393 node sort key with UNUSED is does not re-sort when you use placement sets
HPCPBS-30325 Job starter returns hang for minutes when server sends a lot of jobs to start on a node, delaying job starts for minutes
HPCPBS-30314 Unsetting attribute on all vnodes of multivnode host crashes server (e.g. pbsnodes -C "" <host>)
HPCPBS-30313 large pbs comm network breaks too often (marks thousands of nodes down)
HPCPBS-30289 PBS Pro: Comm Daemon has a low limit for max. open files limiting connected mom daemons to circa 500
HPCPBS-30276 qsub command failing with libcurl error
HPCPBS-30245 Moved jobs are listed in qstat output after server restart
HPCPBS-30193 Job which conflicts with top jobs/reservations can be run by scheduler if the last resource in the select statement requests 0, pushing out start time of top jobs
HPCPBS-30061 Topology info truncated
HPCPBS-29834 qsub With '-lselect=2 -lplace=scatter' Takes Extra 10s Every Time
HPCPBS-29824 When a user submits a job with an invalid resource name, instead of the job being rejected and error returned to qsub, the job is accepted and a PBS job ID is returned to the user
HPCPBS-29680 pbs snapshot should pass over files it can't read
HPCPBS-28272 Running exclusive reservation nodes showing as free if reconfirmed or altered
Thanks
-Scott
