Hello Everyone,
Please find the below newly added features which will be available in the upcoming SimLab release (SimLab 2024.1).
Results
- Compare Results: Results > Compare
- Following enhancements are done in the compare results.
- Change of the Compare Results approach. While doing the multiple window mode for a single database, in 2024, the database has been duplicated whereas in 2024.1, an empty database is created where we can load another database.
- During multiple window mode, a single window can be maximized and restore.
Electronics
- Equivalent Material: Electronics > PCB
- Added the functionality to compute the PCB equivalent material with temperature dependent elastic properties. It is supported for “Preserve all layers” and “Composite shell” PCB layer simplification types.
Mesh
- Surface Mesh & Re-mesh: Mesh > 2D Mesh
- Performance has been improved for mesh body input with more edges.
- Surface Mesh & Re-mesh – Quad: Mesh > 2D Mesh
- Performance has been improved for a body input with more faces.
Tools
- Distance: Home > Measure
- Enhanced to Measure distance between CAD and FEM entities such as,
- CAD Vertex to Node
- CAD face to Node
- CAD edge to node
- Move: Home
- While resolving the cracks by using move nodes, it will post a message as “All crack / wedge elements are resolved”.
Thanks & Regards,
Santhoshkumar
Sr. Manager, Quality Assurance
Altair | Nasdaq: ALTR
Connect with us: LinkedIn | Twitter | Facebook
#OnlyForward
SimLab learning center (SLC) | SimLab FAQ
