In our rapidly evolving technological landscape, the need for high-performance integrated circuits (ICs) has soared, driven by the explosive growth of the Internet of Things (IoT), autonomous vehicles, and artificial intelligence (AI). These applications demand ICs capable of processing enormous data volumes swiftly and efficiently. However, as the traditional avenue of scaling transistors - often referred to as Moore's Law - reaches its limits, the costs associated with advancing process nodes in semiconductors become increasingly burdensome. A fresh approach, known as system-in-package (SiP) integration, specifically 3D IC or chiplet integration, has emerged to circumnavigate these challenges and continue enhancing performance.
The End of Moore's Law and the Need for System-Level Scaling
For decades, the semiconductor industry has been guided by Moore's Law, which predicts that the number of transistors on a chip doubles approximately every two years. However, as we approach the atomic scale of transistors, the cost and complexity of further scaling are becoming untenable. This has necessitated the exploration of alternative strategies for performance improvement. System-level scaling, otherwise known as SiP integration, offers a promising solution. It combines multiple functional blocks or chiplets into a single package, enabling a mix of different process nodes for improved performance and increased flexibility. This approach allows for integrating specialized chiplets, each optimized for specific functions, resulting in enhanced system-level performance.
System-level scaling, or SiP integration, offers a promising solution by combining multiple functional blocks or chiplets into a single package. Rather than relying solely on transistor scaling, SiP integration enables a mix of different process nodes, allowing for greater flexibility and improved performance. This approach enables the integration of specialized chiplets, each optimized for specific functions, into a single package, resulting in enhanced system-level performance.
The Benefits of SiP
SiP integration offers three distinct advantages:
- Performance: 3D IC integration facilitates the combination of chiplets from different technology nodes, allowing designers to exploit each node's benefits. This strategy leads to superior overall system performance by integrating high-performance components.
- Cost: SiP integration reduces scaling costs for entire monolithic chips by utilizing chiplets optimized for specific functions. It enables the reuse of existing chiplets and integrates off-the-shelf components, optimizing resource utilization and cutting development costs.
- A mix of Different Process Nodes: SiP integration offers flexibility to combine chiplets from different process nodes within a single package, allowing designers to optimize performance, power consumption, and cost for each individual chiplet. This leads to an overall superior system design.
The Need for Advanced EDA Tools
Despite the benefits offered by SiP integration, there are significant challenges that need to be addressed. Among other things, we have the following big challenges:
- Thermal and Power Dissipation: As more functionality is integrated into a smaller footprint, 3D IC integration increases power density, leading to higher levels of thermal dissipation. Efficient thermal management becomes critical to prevent overheating and maintain reliable operation.
- Thermal Stress: The dissipation of heat in 3D ICs can create temperature gradients, resulting in thermal stress within the package. These thermal stresses can lead to reliability issues such as interconnect failures, warpage, and delamination.
Moreover, Electronic Design Automation (EDA) tools specifically tailored to handle these system-level challenges are scarce. Traditional EDA tools primarily focus on individual chip design and lack the comprehensive capabilities to address these system-level challenges. To successfully navigate these new challenges introduced by 3D IC integration, we need advanced EDA tools capable of accurate thermal and power analysis, thermal stress simulation, and robust design optimization. These tools will empower designers to make informed decisions early in the design process, ensuring reliable operation and mitigating potential issues associated with 3D IC integration.
Altair Multiphysics suite
Altair® SimLab®, a multiphysics Electronic Design Automation (EDA) solution, empowers engineers to address thermal concerns. By leveraging high-level specifications, such as the size of each die, number of micro bumps, package dimensions, layer number, BGA configuration, and power consumption of each die, our EDA solution can create a 3D IC system from scratch and perform rigorous "what-if" analyses to validate the floorplan from a thermal perspective.
SimLab® provides engineers with an intuitive interface to input high-level specifications of the 3D IC design. By simultaneously considering parameters like power density, thermal conductivity, and heat dissipation characteristics, engineers can create a virtual 3D IC prototype. This virtual model is then subjected to advanced thermal analysis and thermal stress simulations.
The strength of SimLab® solution lies in its ability to conduct thorough "what-if" analyses. Engineers can explore various floorplan configurations, power profiles, and cooling mechanisms to identify potential thermal hotspots, weak points, and stress-prone areas within the 3D IC system. This capability empowers designers to make informed decisions to optimize thermal performance and ensure reliability in the final product.
Conclusion
As the demand for high-performance ICs continues to grow with the emergence of IoT, autonomous cars, and AI, 3D IC integration offers a viable path forward to overcome the limitations of transistor scaling. By adopting SiP integration, designers can leverage the advantages of performance, cost optimization, and the mix of different process nodes. However, to successfully embrace this paradigm shift, the industry must invest in developing advanced EDA tools capable of addressing the unique challenges introduced by 3D IC integration. Only through this holistic approach can we unlock the full potential of SiP integration and meet the ever-increasing performance demands of the future.
