Function of "trim_depvect" can't be found in help
Zheng Guotao
Zheng Guotao Altair Community Member
edited December 2023 in Community Q&A
Function of "trim_depvect" can't be found in help document
How to find the full explanation of all Hypergraph function and the explanation how to use it in Hypergraph.
Now most of function can be found in help document, but part of them aren't in the help document such as "trim_depvect"
Best Answer
  • Michael Herve
    Michael Herve
    edited December 2023 Answer ✓
    Hello @Zheng Guotao ,
    this function is not documented as it is generally not used intependantly.
    Below here's the Templex code of that function:
        *BeginTemplexFunction()
            *BeginText()
                function trim_depvect(dep_vect,ind_vect)
                    if(numpts(dep_vect) > numpts(ind_vect))
                    result = dep_vect[0:(numpts(ind_vect)-1):1]
                    return result
                else
                    return dep_vect
                    endif
            *EndText()
        *EndTemplexFunction()
    which means this functin truncates first vector if its length is different from second vector.
    Hope this helps,
    Michael
  • Michael Herve
    Michael Herve
            *BeginText()
                    return result
                else
                    return dep_vect
                    endif
            *EndText()
    Hope this helps,
    Michael
  • Zheng Guotao
    edited November 2023
            *BeginText()
                    return result
                else
                    return dep_vect
                    endif
            *EndText()
    Hope this helps,
    Michael
    Michael, thanks for your feedback
