Does anyone know where the "Count" option moved to in the new interface?
The "tool finder" says that it's in the "Validate" ribbon:
But it doesn't appear on my "Validate" ribbon:
Yeah, I don't really see a replacement either. The browser now shows the numbers for the whole model and when doing selections it shows you how many are selected. You can also switch from one type to another and it maintains the selection. So if you change the selector to components and select a component then change the selector to elements it will select the elements in the component and show the number of elements selected.
Let me know if the helps and what your specific use case is so I can look into a specific solution. Thanks.
Yeah. I guess that method works. Thanks.
