I'm triying to calibrate a powder material in EDEM, this powder in the empiric experiment, has a compressibility of a 10% under a pressure of 6986Pa. When I want to calibrate the material with EDEM, teorically for to play with the compressibility of the material, I can to adjust the Young Modulus, but even increasing the Young Modulus in a high value, I can't achieve the compressiblity of the 10% under the metioned pressure (I obtain compresibilties of 20-30%).
I'm using doble spheres with a 1,5mm size, and I understand that the major part of the compression that the powder experiments in EDEM comes from intergranular relocation, and not from the stifness of the particles, due this, I can't achieve the specified compressiblity, and increasing the Young Modulus I lead to a very long simulation time.
How can I play with the compressiblity of the powder to achieve the correct value?
Thanks.
