Warning is as follows.
I connect the master node of the RBODY to beam element.
WARNING ID : 448
** WARNING IN RIGID BODY DEFINITION
DESCRIPTION :
MASTER NODE 1795 IS CONNECTED TO AN ELEMENT
-- RIGID BODY ID : 1633
-- RIGID BODY TITLE :
RIGID BODY ID 1634
PRIMARY NODE 1796
NUMBER OF NODES 8
SURFACE LINKED TO BODY 0
SKEW NUMBER 0
SPHERICAL INERTIA FLAG 0
REMOVE SLAVE NODES FROM RIGID WALL(IF=0) 0
CENTER OF MASS FLAG 1
ADDED MASS 0.000
ADDED INERTIA 0.000 0.000 0.000 0.000 0.000 0.000
SECONDARY NODES
1433 1435 1437 1456 1460 1471 1491 1495
Is it wrong?
some nodes must be needed between master node of the RBODY and BEAM3N?
Thanks
