How to obtain .OP2 or .xdb Output result file?
I was wondering how can I obtain the .OP2 or .xdb files needed for submodelling by the Post by displacement option in HypermeshOptistruct?
An imaga was attached.
Thanks in advance.
Request output in .op2 format.
0 -
Where is the information on how to export the .op2 file?
0 -
Hello sbasude,
You need to activate OUTPUT card
Analysis tab --> control cards --> Search for OUTPUT
Now this card should be on on ypur entity tree.
Once you click on output card make number of outputs = 1 or the number of outputs you like
On keyword = OP2
Now after solving it will create you the op2 file /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
1
