Is it possible to create transient response analysis for fluid domains?
User: "Dennis_20682"
Altair Community Member
Updated by Dennis_20682
Hello everyone,
i'm trying to do a transient response analysis for a empty room using hypermesh/optistruct. For that i only modelled the fluid part of the room an created Absorber elements at the boundaries with a impedance, that results in a small amount of absorption. A direct frequency response analysis works perfectly, even though the results are not as wished. Trying to change the analysis to a transient one results in the following error:
 A fatal error has occurred during computations:
  *** INTERNAL PROGRAMMING ERROR # 251 ***
  Specified vectors (1 - 1) out of range (1-0).
Thank you all in advance
1 - 2 of 21
    User: "Xiaolei"
    Updated by Xiaolei
    Hi Dennis,
    Transient analysis for fluid is supported.
    The attached is an example for your reference.
    Thanks.
    Xiaolei
    OP
    Hi Dennis,
    Thanks.
    Xiaolei
    This helped me a lot, thank you very much.
