I ran PBS Pro for the first time in a long time and it ended up being state:down. (Currently, if you restart it, it will become state: free and you can use it)
Since the following logs existed, I suspect that there is a problem with the communication between the server and MoM.
mom_log:
01/25/2024 15:15:30;0001;pbs_mom;Svr;pbs_mom;im_eof, Premature end of message from addr xx.xx.xx.xx:15001 on stream 1
01/25/2024 15:15:30;0002;pbs_mom;Svr;im_eof;Server closed connection.
sever_log:
01/25/2024 15:15:26;0001;Server@xxxxxxx;Svr;Server@xxxxxxx;svr_save_db, Unable to save server data base Execution of Prepared statement insert_svr failed: no connection to the server
01/25/2024 15:15:26;0001;Server@xxxxxxx;Svr;Server@xxxxxxx;panic_stop_db, Panic shutdown of Server on database error. Please check PBS_HOME file system for no space condition.
01/25/2024 15:15:26;0002;Server@xxxxxxx;Svr;Server@xxxxxxxr;Stopping PBS dataservice
01/25/2024 15:15:30;0002;Server@xxxxxxx;Svr;Log;Log closed
I'm using firewall, does opening ports 15001-15009 and 17001 in TCP prevent state:down?
I'm going to set the firewall settings as follows. (port part of "firewall-cmd --list-all")
ports: 15001-15009/tcp 17001/tcp
The PBS version uses 19.2.6.
