Dear sir
I have attached the apparatus and python analyst code and setting file for direct shear test in Geotechnical engineering that I have coded and also the picture of the error when I run the python code in spider program. I want to ask is there anyone can help in python coding for direct shear test to solve this error and reach to a suitable code?
Hi Abbas,
Judging by the error message you got, it seems like the SStress[s_1_start:s_1_end] array is empty and the np.amax function doesn't work on empty arrays. What I'd suggest you do is checking if the SStress array is empty to begin and check if s_1_start and s_1_end are equal. You can also just catch this exception and ignore it if you by doing:
try: s_1=np.amax(SStress[s_1_start:s_1_end]) except ValueError: pass
<span class="hljs-keyword"><br /><br /><span style="font-family: arial, helvetica, sans-serif;">Hope this helps you.</span><br /><span style="font-family: arial, helvetica, sans-serif;">Best regards,</span><br /><span style="font-family: arial, helvetica, sans-serif;">Renan</span></span>
