Adding a fix
User: "Tomaaslet"
Altair Community Member
Updated by Tomaaslet
Hi
I have to add my first SLC  fix to our server installation (maintenance build 4.4.6.0.5818 ).
And I found this - and I guess it is okay (4.4.6.0.5828)
So I have downloaded this fix - and when I did this - I saw that the file size is the same as the original installation. Then I was a little worried and would like to know
1. Is this an entire new installation ?
2. The customized files (cfg etc.) will they be overwritten ?
Thanks
Best regards Tom Aaslet
1 - 1 of 11
    User: "Nico Chart_21517"
    Updated by Nico Chart_21517
    Hi Tom,
    Yes each maintenance build is an full installation to replace the existing installation of WPS / SLC.
    You do need to watch out for config settings in the file wps.cfg in the top level installation folder for SLC:
    C:\Program Files\World Programming\WPS\5\wps.cfg
    Custom settings are often placed in that file so make a copy of the file somewhere safe before upgrading.
    Best Regards,
    Nico
