Hello! I have a engine block mesh with 8 cylinders with results in [nodeid, radial displacement] format.
In the past I have generated bore distortion results using a [nodeid, xyz displacement] data. Is there a way I can use the [nodeid, radial displacement] results to generate bore distortion results? or is there a way in simlab where I could generate xyz displacement for each nodes from radial displacement?
I also would like to know if you can import multiple results/subcases in simlab. if yes, how can I do that?
Thank you very much in advance!
