Dear all,
Lately I am having some problems solving a problem that might seem 'trivial', however I am still having problems getting some meaningful results. As seen from the files attached, the problem consists of two aluminium plates connected with a steel bolt and a bushing. There is a press fit of 0,2mm (if I remember well) between the bushing and the two plates. The upper plate has one of its sides fixed and a compressive force of 90 kN is acted on the lower plate. Although I have simulated the contact* between all components (plates, bolt, bushing) and ran a quassi static NL analysis, I keep getting extremely high stresses at the area seen on the attached picture. It is probably some mistake with the contact there but I cannot find it.
Please have a look on the attached .hm file. There are no contacts defined to allow you to use your own approach to the problem. You can use any of the latest HM versions to setup the problem.
Thank you in advance for your kind assistance.
*: a number of approaches used: friction, no friction, slide, freeze etc.
