while installing the software, errors faced are placed at attachment. request someone to please help me through the software.
regards
looks like you have a license created with a different hostid (mac address) than the machine you're trying to install it.
The license file is created based on the hostid (ethernet mac address) of a specific machine, and it is only suited for that machine.
It the license code does not match with your machine, then, it won't launch.
I assume that you have provided a different machine mac address while requesting the license file.
If that's the case, you will need to request again, with the correct ethernet physical address.
