I did a dynamic explicit simulation in OptiStruct. I set up a perfectly plastic material using MAT1/MATS1 with H = 0 to represent perfectly plastic material.
The simulation is smooth without any error but I find out the von Mises stress of the shell elements exceeds the yield strength of the material. The yield strength I set up is 250MPa but the stress from simulation exceeds 250MPa and seems 322MPa is the yield strength..
I tried the nonlinear static analysis and the stress is limited to 250MPa. The problem only happens when dynamic explicit simulation is adopted.
Any clue or any suggestions to solve this problem? I attached the FEM file for your reference.
Thank you.
