Good morning Altair community.
I need your help regarding the fatigue analysis of this component, a notched aluminum alloy sample (see attached image).
The sample is subjected to a bending force, the load time history is in figure, with R = 0.1, frequency 5Hz.
From experimental tests, I obtained useful data material fatigue properties (in as-build conditions).
SN curve material properties:
"slope-intercept_1segm", Rm = 414MPa, Rs = 232MPa, SR1 = 1073, b1 = -0.17, NC1 = 2e + 06, FL = 90MPa.
Due to bending direction, the top of the sample is expected to be in compression and the bottom in tension. In fact, from fatigue tests, failure occurs on the underside.
However, from the fatigue simulation the contour shows high damage on notched side and limited damage on flat side, different from what expected and verified.
What could be the cause of that? Did I set something wrong?
Second question: with real values SR1, b1, NC1, FL (matfat parameters), do I have to enter specific values in the PFAT card, like surface finish, treatment real, KF, or do I leave them by default?
Third question: in addition to the damage / life outputs, is there a way to obtain other outputs, such as mean stress, etc.?
Many thanks in advance for your help.
Thomas
