I have a model running in OptiStruct. I am working of a non-linear optimization of an a-pillar structure of a vehicle using equivalent static loads methods. The explicit-model is setup for roof crush test.
The explicit analysis is running correctly in OptiStruct but I have a problem with the optimization side. As you can also see in plots below, the lower boundary constraint is violated but the optimizer gives OPTIMIZATION HAS CONVERGED and
FEASIBLE DESIGN (ALL CONSTRAINTS SATISFIED) messages after 5th iteration and finally writes JOB COMPLETED.
My objective is to minimize mass by reducing 9 thickness design variables.
Can you please help me for understanding how convergence is checked and evaluated by the optimizer?
Kindest regards,
Emrah Tokyürek
