I have problems creating an model.
The model includes an pretensioned Bold that applies preassure onto an orthotropic material.
Therefor I have jused the Pretension Manager in Optistruct and the card image MAT9ORT for the material.
Now I have two problems.
The first problem is, that the material properties of the orthotropic material are time dependant and I have no clue how to incorporate this into my model.
The second problem is with the material stability conditions, I do not see any possibility to fix this without changing the material properties, but those are, naturally fixed:
*** ERROR # 1551 ***
for material id = 2 referenced from property id = 1.
Material coefficients Gij on MAT9 card produce material matrix with negative
eigenvalues. This violates material stability conditions.
Eigenvalues of G: -8.915074E+02 1.565340E+01 9.060199E+00
3.612000E+00 2.535000E+00 3.612000E+00
