Hallo,
I am very much interested in the recently introduced equivalent static load method in Optistruct. I read in the manual that optimization of an explicit dynamic problem is possible.
I would like to optimize an explicit dynamic metal forming problem (until now calculated in Radioss) with nonlinearities in geometry, material and contact.
Using Optistruct I would like to implement a free shape optimization and allow the tool’s nodes to be moved. The optimization response should be an external calculated best fit value. And so the optimization algorithm will change the tool shape until the target performance comparison of the metal sheet is in an appropriate range.
1. Do you think that is possible?
2. Are there examples concerning metalforming/ESLM with HW?
3. Are external Responses allowed with ESLM if not are there alternatives to minimize the deviation between a deformed sheet shape and the desired final result?
Regards
Hannes
