I have simulated a Composite Bar under tension and pressure loading. By manual calculation I would expect a stress of approx. 320 MPa and the same stress for tension and pressure loading.
The FE-Simulation shows as a result:
Tension Load: P1 (major principal) = 290 MPa, Composite Failure Index = 0,19
Pressure Load: P1 (major principal) = 5 MPa, Composite Failure Index = 0,15
Do you know why the pressure stress is so much lower compared to the tension stress? I would even expect a higher Failure Index under pressure load, as the bar will probably fail earlier in this load case? Can you please give som advice?
