I am doing a shape optimization of a 2D circular plate with some holes in it.
Design variable:-
i)radius of the hole
ii)position of the hole on the plate
Objective:-
Maximize the gap between the natural frequencies of the plate.
constraint:-
i) the center distance between the holes should be greater then a particular value.
( this one is required to ensure the holes should not come very close to each other or should not overlap each other during optimization.)
I can define the design variables with morphing and the objective function with different equations and responses.
My only problem is i don't know how to put a constraint like,
center distance between the holes > some value.
Hence i am wondering, if i can define the coordinate of a node as a response then it will be possible to create an equation and response for the difference of the coordinates which will ultimately give the distance between the points.
Please correct me if i am wrong.
One more thing i want to add, as the plate is circular i have to use cylindrical coordinate system (r and theta coordinate ). thus the distance between the holes can be the difference between the theta coordinates.
