i am trying to optimise a laminate modelled with a PCOMP card. I am using topology optimisation with optistruct.
I have designed 2 layers of different angles each with a thickness of 1mm. Getting the results I of course find areas in the model with a total thickness of 2 mm. In some areas one layer vanishes and the other layer obtains a total thickness of 1mm.
My question is if it is possible to constrain the total thickness of the laminate to a thickness <= 1 and still leave the thickness values of 1 mm for each single layer?
thanks for your help
tom
