How to map variable pressure distribution on a surface
Hi, I want to map a distribution of pressure over a bicycle saddle based on the weight of a person seating on it. As it is not a constant load distributed over the area, how can I implement the distribution of pressure with a varying load or a load that changes (i.e. starts from a reference point and slowly reduces as it is spread over an area)?
Is there a function I must use or reference a table of data? Would really appreciate the help. Thank you.
you can create a pressure filed using an equation
go to Analysis >>Pressure and change 'magnitude' to 'equation'.
Then, define a proper equation to your case, optionally in a local coordinate system.
