Dear community,
I have a custom SBR workflow in which I compute the electrical field in two simulations : (1) for a real feed (2) for an equivalent feed excited by the real feed.
For final results, I need to account for the path length from the real feed to the equivalent feed, corresponding to an equivalent phase shift (Phii in eq 45).
Can I do it directly in Winprop or I need to save the rays data file so I can add this path length in the path 'duration' or ray 'shift' columns ?
I have tried to compute the electrical field strength Etot from a simple model to check for the second solution, however I am unable to get same results calculated by ProMan software, according to help document [1], where I use the 'delay of path' field in ns to compute its length to get Phii, and the 'field strength' field as Effi as defined in eq. 45 from the ray data file [2].
[1] https://2021.help.altair.com/2021.1.2/winprop/pdf/Altair_WinProp_User_Guide.pdf, section 5.2 (superposition of rays)
[2] https://2021.help.altair.com/2021.2/winprop/topics/winprop/user_guide/proman/results/proman_results_type_ray_data.htm
Thank you,
