Hello.
 I have a model with already applied contour. At the moment I manually have to advanced query and perform my input in the popup window. This will then be exported into a csv file. Since I have to perform this process over and over again, I would like to automate it via a tcl script. Applying the contour is already done via hwc commands in the tcl script. My problem is now how I can write my user selection from the popup window in the tcl file and then export the results to a csv file.
 Thanks in advance.
