材料の設定をしている際、状態方程式の入力は必要だと考えるのですがどのような操作をすれば入力できるのでしょうか?教えていただけると幸いです。
It's very easy. Attached a video to explain the methodology for Hypermesh and an extract of RADIOSS Online Help.
Important information: EOS is used by Radioss to compute the hydrodynamic pressure and is compatible with the material laws:
Mathieu
Hi, It's very easy. Attached a video to explain the methodology for Hypermesh and an extract of RADIOSS Online Help. Important information: EOS is used by Radioss to compute the hydrodynamic pressure and is compatible with the material laws: /MAT/LAW3 (HYDPLA) /MAT/LAW4 (HYD_JCOOK) /MAT/LAW6 (HYDRO or HYD_VISC) /MAT/LAW10 (DPRAG1) /MAT/LAW12 (3D_COMP) /MAT/LAW49 (STEINB) /MAT/LAW102 (DPRAG2) /MAT/LAW103 (HENSEL-SPITTEL) Mathieu
ありがとうございます。とても助かりました。
