System with the following description needs to be modelled:
4 permanent magnets arranged in a single ring
Within the magnetic ring, 2 conductors are placed in contact carrying high current in the range of 150-170 A. Conductors are clamped and cannot rotate.
the conductors are the retracted to create a gap in 2-3 mm range. An arc gets created between the tubes. Interaction of magnetic and electric fields causes lorentz force to be generated which acts on the arc. Schematic is included as attachment.
I am new to simulation and Altair . Thus need help in knowing about a tool and the steps required to analyse this system for the force created and the magnetic field setup in the region. Also need to analyse the effect of current variation on the magnetic field and the lorents force.
