Hi
If I want to use the 2nd order Transfer Function in the Altair Embed platform, there are two ways I can take the Transfer Function Ready made block from the embed tool box or I can create a 2nd order expansion form using embed native blocks.
Functionality wise both are the same. If I give the same input to both models and it should produce the same outputs. But here I have observed there is some difference.
can you please help me to come out of this problem?
I am sharing the required diagrams, test data and Screenshots results.
Please check the attachment
Thank you,
R Sanjeev
