Greetings fellow forum users,
I am working on a static linear analysis of a steel space frame welded structure. I am using tria3 and quad4 for the steel profiles and CBUSH with K1-6 line=1000000. Common FEA wisdom proposes to try different mesh sizes until the results converge towards a final value. Doing smaller mesh sizes models only increased the stresses (this happens at CBUSH weld lines and at sharp corners) and doesn't converge in a reasonably small size mesh. Also, the results are simply not backed by practice and by field measurements!
I made a small test, pictures in attachment, of a plate constrained in the 4 corners with SPC (1-6) and added a force in an arbitrary position. Since stress is a derived value of strain and displacement in this situation is the sum of all strains, I am focusing on the displacements or the compliance in the .out file. So what I get is that with finer mesh I get bigger displacement.
With this I conclude that it is not the common conception that the area of the element is in question, that smaller A gives bigger stress, meaning the error is in the stress calculation, but that the compliance of the stiffness matrix is changed, I see this in the out. file and this totally freaks me out! As far as I get, stress in this situation is out of plane and that may not be compatible with tria3 and quad4 so I tried the other way, in-plane bending, the convergence of displacement/stress still doesn't occur.
Does someone understand why is this the case?
Thank you,
Viktor
