Hi guys,
I run a injection molding in SimLab.
Then I check mesh_quality.txt file, there are 44 element failed AR criteria (range 1.01-134.48)
But when I go to Mesh>>Verify>>Quality check to cleanup element.
I compute the AR then I have the range below:
The range in mesh_quality.txt and in Quality check is different.
Moreover, in quality check for tet element, there no 4 others criteria for cleanup like in .txt file.
Please help me know how to fix these mesh in SL.
Best regards,
James
