Hi experts,
I am using HyperForm, but I can not find the way how to define FLC for material.
Anyone could help with that?
Thanks in advance!
Hi James,In HyperForm, to run the analysis FLC is not required to define for the materials. FLD can be visualized in Hyperview for your simulated results.For that, you can either use the file containing the FLC data, you can create the FLC using the strain hardening and sheet thickness information, or provide the Major and Minor strain values. (refer to the attached video for more info).Thanks.
