Altair RISE
Nominate Yourself Now!
Heat analysis with HyperWorks CFD, but with rotation movement?
User: "James Lewis"
Altair Community Member
Updated by James Lewis
Hi experts,
I'm want to use HyperWorks CFD for a heat transfer analysis.
My model is a sensor inside a car wheel with rotation.
I'm quite clear about how to do heat analysis, but I don't know how to consider the rotate motion of the wheel.
Anyone could suggest me any ideas?
Yokohama to develop sensor for monitoring tyre wear - Asia's Ultimate Tyre  Awards
1 - 4 of 41
    User: "acupro"
    Updated by acupro
    What are all the physics you are trying to capture?  Please include/describe with as much detail as possible.  And to what level of accuracy?
    User: "James Lewis"
    OP
    I try to capture the heat that the chip generate during working inside the wheel.
    But I'm not sure that how the rotation of the wheel will affect the temperature.
    User: "Jagan"
    Updated by Jagan
    You can use reference frame if you are solving it in steady state. If the tire is rotating at a constant speed I believe air inside is viscous enough to rotate almost at the same speed but it will lag during acceleration and deceleration.
    User: "James Lewis"
    OP
    Really thanks for your information!
