There are two shell parts, placed one above the other. I can see that there is no penetration. But, still it shows 1mm penetration. Why?
I have attached the model, please have a look at it.
Thanks.
Both your shells are 2mm thick, so the gap between them needs to be 2mm (0.5 x Main + 0.5 x Secondary)
I know that 'physically' these parts would not be penetrating as they are perpendicular to each other, but with Type 7 interface they do penetrate!
Since the gap extends around the end of elements there would be penetration whichever is defined as Main and which secondary
If you cannot offset the parts or edge by a further mm, then you should look at using Interface Type 25 with Ishape and Igap0 values set appropriately
Both your shells are 2mm thick, so the gap between them needs to be 2mm (0.5 x Main + 0.5 x Secondary) I know that 'physically' these parts would not be penetrating as they are perpendicular to each other, but with Type 7 interface they do penetrate! Since the gap extends around the end of elements there would be penetration whichever is defined as Main and which secondary If you cannot offset the parts or edge by a further mm, then you should look at using Interface Type 25 with Ishape and Igap0 values set appropriately
I created the TYPE25 contact (please check the attachment) for these two parts. But in penetration checker this TYE25 contact is not getting listed. Can't we check the penetration and intersection is TYE25 contacts?
