I am using STACK model in Radioss.
After setting laminate, I confirmed thickness and layup pattern in HyperMesh.
then layup pattern seems to be double than I expected.
could you let me know to do correct. setting.
I attached picture which showed layup pattern and hypermesh view with composite layer view
I expected I can get 3 layer, but in hypermesh which has 6layers.
this is issue I would like to solve.
